325i Steering
Hi ,
Hope someone may be able to help here as I am lost for anything else to try.
I have an 89 325i Motorsport Cabrio that I put in the garage for around a year and a half (due to company car) . I thought this year I would get it out and put it back on the road.
When i took it out the steering was really bad i.e. tight would not return and lots of play.
I replaced the front springs and strut top bearings as I was told these were seized but this did not help , I then replaced pump still no joy so i replaced the rack and pipework and the trackrod ends and this is a little better I have checked the column and it seems free enough when disconnected from rack.
The steering is easy enough now (still not what it used to be) but I have huge amounts of play which make the car no fun at all to drive .
Does anyone know of anything else that would cause this problem . Could the column be faulty in some way ?
I cant think of anything else to try (i have not changed linkage from column to rack as this looks ok)
Please help !!!
thx David W
Old 06-30-2004, 05:58 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Is there free play in the rubber coupler that goes from the friewall to the rack?
Old 06-30-2004, 09:09 AM
To be honest I have not checked this to any degree, but when i changed the rack it seemed ok .
Is this the most likely culprit ?
I cannot think of anything else as everything has been replaced.
I will have a better look at this.
Old 07-01-2004, 12:30 AM
Play in the steering would most likely be caused my the coupler if you have already replaced the rack and the tierods...
Old 07-01-2004, 07:23 AM
Have you checked your tires for flat spots???>>After sitting that L O N G
it prolly drives horrible ~
Old 07-09-2004, 05:54 PM
The tyres are all new , I had the car resting on axel stands when in garage and have had the wheels re-balanced etc and the wheel alignment re-done.
I still have to check the coupler from rack to column but i hope to do this tomorrow , I will let you know how i get on.
Cheers Dave..
Old 07-11-2004, 03:04 AM
It turned out that the coupler was split , I did not see this when it was off the first time but it had a major split in the rubber , I changed this and the steering feels great now.
Thx
Old 07-21-2004, 02:41 AM
jase007's Avatar
Dave:
Do you mind us asking how much for the coupler? I am assuming it is a dealer supplied item. Were you able to get the bushings only or was the coupler itself split?
Thx
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 07-21-2004, 08:54 AM
