Pilot bearing Q
I put a used M20 in my 325 Manual trans. E30. It came out of a automatic transmission car. Now that the whole car is together, I realized I forgot to put a new pilot bearing in the end of the crankshaft. Would that engine have even come with one if it was from a automatic trans car?
Old 07-20-2004, 09:41 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
More importantly, did you change flywheels?
Old 07-20-2004, 02:40 PM
I was at least smart enough to know I needed to use my flywheel and a new OEM clutch & throw-out bearing.
Still, I'm sure it wreck havoc not to have that support on the input shaft, if in fact Automatic car's cranks don't come with them.
Old 07-20-2004, 02:51 PM
You would be correct, the automatic transmissions dont have pilot bearings. However the flywheel from your old motor would have one. Is it possible that it was not pressed out when you took the flywheel off?
Old 07-20-2004, 02:53 PM
The pilot bearing on E30's is actually in the end of the crank. There is a hole in the middle of the flywheel and the input shaft goes through that and contacts the bearing on the other side. I only know that much because I have my old motor, and the original pilot bearing is still in that crank. I was just hoping maybe the automatic cars came with them or used them too.
Old 07-21-2004, 08:24 AM
as an E30 pilot yourself, do you spend much time on e30tech.com ?
Old 07-21-2004, 11:49 AM
jase007's Avatar
Daniel:
My guess would be no for Jared as he is a moderator here and is on the sister Porsche boards as well.
I am starting to look over there b/c seems to be more technical input from a greater number of people. Similar to www.bmwe30.net.
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 07-27-2004, 09:47 AM
How dare you speak for me!!!!!!!
actually, no, i dont get around there much. Guess i'll have to check it out..
Old 07-27-2004, 09:54 AM
