my hood release lever under the dash has broken off leaving the cable behind and I can't get the hood to open even if i pull really hard.
Is there another way of opening/releasing the hood aside from maybe pring it open? please help thanks |
In the shop at Pelican
If there is enough cable left, just use a good pair of pliers to pull it open...
I forgot it is an 85 325
tried that and still will not release
thanks |
Kepp pulling.. I've had this happen before and it takes some effort. Perhaps try grabbing the cable over the side of the pliers ad rotate as you pull to simulate the effect of a pulley
You have PM.
Mike
1972 911T Targa 1994 Volvo 850 Wagon 1988 BMW 635 CSi |
elbcbimmer - my lever broke on my '88 because the release mechanism was corroded and needed excess force to pull it open. Try using some vise grips to really hold the cable, then pull nice and hard to open it (no jerking though)
Bret Derrick '80 volvo 240 '90 bmw 325i '88 bmw 325ic |
I had that problem and it turned out that I had left something under the hood when I shut it. I got the hood open by pressing down on the hood at the latch while an assistant pulled the release lever. (The car was not a Bimmer)
===Bernie=== '88 BMW 325is 75 Porsche 914 1.8L |
also , if this still does not work , go grab the longest flat head screwdriver you have , and go to the front of the car , on the driver side , thru the grill about five or six or so inches to the inside of the highbeam there will be two bolt heads prettty much horizontalto each other , in the middle of these is a hole about a inch wide , stick the screwdriver tip in this hole and turn it around clockwise or either counterclockwise , it should pop right open , its a generally good idea to carry a big flathead just for this purpose , as this happes quite often from what i hear
Good Luck!!!!
Thank you all for your sugestions - still have not tried it but will let ya all know of the results
