What kind of bulbs for instrument cluster?
The left side of my cluster is not working--gas gauge and speedo. I've read the instructions for removing the cluster, but there doesn't seem to be any reference to the type and size of bulb needed to replace the originals in there. Could someone post this info? Thanks!
i dont know what number it is but i think its 194 or 168... not sure... go to pepbeys they have this catalogs on light bulbs for car you'll find it there...
If you go thew parts store route, go ahead and replace all the bulbs in the cluster. Sometimes the new bulbs aren't exactly the same brightness as the old and your cluster still won't be lit evenly.
can anyone post the part#'s & quantities for a "full set" of bulbs for the instrument cluster?
trying to avoid having to take it out just to figure ou t which bulbs, then back together to drive to the store, etc, etc,. thx! richard |
In the shop at Pelican
What year and model?
'89 E30 325i/Sedan
after a bit of help from Tom in sales, I've been assured that the right assortment of bulbs for a "full set replacement" in an '89 325i instrument cluster is as follows:
> 07-11-9-978-372, 12v 3watt bulb, quantity 3. ($.70 each) > 62-11-1-375-774, 12v 2watt bulb, quantity 2. ($1.55 each) > 62-11-1-368-299, 12v 1.2w bulb, quantity varies per model, probably 8 would cover it. ($.75 each) (This is the small bulb that has a plastic base that 'twists' into place on the back of the instrument panel) NOTE: if you enter these #s into the database, tho, you get other responses/blank data ... despite this, i'm told to ignore the database & just enter these order #s into the comment fields ... once they arrive, i'll post a note here as to correct or not =) richard Last edited by blakersE30; 09-08-2004 at 09:26 AM.. |
While we're on the topic, what type of bulb do I need to use to replace the bulbs on the 6-button clock?
1987 325 eta |
On the same subject. what is the part number for the bulbs on the computer display . (to the right of the radio)
I'm going to put together a bulb kit for the instrument cluster.. Should help you guys out a bit...
