-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   02 sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/180007-02-sensor.html)
kentman 08-28-2004 04:31 PM
02 sensor
can some one tell me what mileage i should change my 02
sensor many thanks.
RS1060 08-29-2004 09:55 AM
Your asking the wrong people. Your car will let you know, assuming you have a OBD I or OBD II model E36. If the O2 sensor goes bad your check engine light will come on and all you have to do is read the codes to know for sure. Otherwise, each inspection, both type I and II require a reading of vehicle faults. So if you have a fault at that time it should be corrected.
Edu 09-04-2004 12:42 PM
I've changed the O2 sensor in my 318 every 30000 miles
Jared at Pelican Parts 09-07-2004 08:32 AM
Factory reccomendation is 60,000 miles...
