Help- Knock sensor fault!!
I just used the peake code reader on on my car and got the fault Knock sensor cyl 1-2!!.
Do I need to replace it or can there be other causes. My car is a 98 318is and I do not hear pinging:confused: |
Someone please:(
Since you seem to be in a hurry...
Until you find someone who can help, start searching the web. Your problem sounds familiar so I'm sure there is info on the internet about it. Good luck. |
May just be ~bad gas......and the knock sensor did what its suppose to do....clear the fault & see if it comes back~:)
Cleared the codes and yep no new codes as yet :)
But now I cant seem to get it to rev freely beteween 4k and 6k, anything I should check?? |
Bump
bump :eek:
What happens when you try to rev it past 4K?
have you checked the fuel pressure at all? Perhaps the regulator is on its way out....
Thanks!
How do I check the fuel pressure? I have heard the Airflow meter can cause a similar problem. Is there a way to test it out? |
put a fuel pressure gauge on it, check the operating pressure...
| All times are GMT -8. The time now is 01:56 AM. |
