Help- Knock sensor fault!!
I just used the peake code reader on on my car and got the fault Knock sensor cyl 1-2!!.
Do I need to replace it or can there be other causes.
My car is a 98 318is and I do not hear pinging
Old 08-31-2004, 03:54 AM
Someone please
Old 08-31-2004, 07:30 AM
Jeron's Avatar
Since you seem to be in a hurry...
Until you find someone who can help, start searching the web. Your problem sounds familiar so I'm sure there is info on the internet about it.
Good luck.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-31-2004, 07:59 AM
BMW Roundel
May just be ~bad gas......and the knock sensor did what its suppose to do....clear the fault & see if it comes back~
Old 09-06-2004, 05:27 PM
Cleared the codes and yep no new codes as yet
But now I cant seem to get it to rev freely beteween 4k and 6k, anything I should check??
Old 09-07-2004, 05:37 AM
Bump
Old 09-10-2004, 05:58 AM
bump
Old 09-10-2004, 04:17 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
What happens when you try to rev it past 4K?
Old 09-13-2004, 03:38 PM
The car sruggles to get to 6K but if remove the vacuum to thr fuel pressure regulator and block it off at the manifold end the problem goes. In fact it runs very well??
Old 09-14-2004, 08:04 AM
have you checked the fuel pressure at all? Perhaps the regulator is on its way out....
Old 09-14-2004, 08:06 AM
Thanks!
How do I check the fuel pressure? I have heard the Airflow meter can cause a similar problem. Is there a way to test it out?
Old 09-14-2004, 08:13 AM
put a fuel pressure gauge on it, check the operating pressure...
Old 09-14-2004, 08:34 AM
