-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   re-setting radio code (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/181058-re-setting-radio-code.html)
Edu 09-04-2004 12:01 PM
Hi,
I would like to know how to reset the BMW radio. I have the code but right now it just states "code - WAIT" it does not allow any numerical entries. I disconnected the power for 1 hour to see if it would reset but it didn't, then I disconnect for 24 hours and nothing happened. Is there a reset switch somewhere on the BMW radios?
I appreciate any help. Thank you
bg_firstbimmer 09-04-2004 01:43 PM
Not sure about the error. Disconnect power for 1/2 hour if that makes any difference.
BMWCowboy 09-06-2004 05:38 PM
U have to leave the key ON for one hour-->turn on with the radio showing CODE...then after one hour enter the correct code
ahofam123 09-07-2004 07:54 AM
I will need to reset the radio code on mine. How can I find out what the code is? Will the dealership have it, or will I have to call BMW?
Thanks.
BMWCowboy 09-07-2004 03:36 PM
Remove radio & there is a serial number on the back of the radio....U might be able to call a dealer but most want you to come in & show proof you own the car--->and they usually charge an hour
