Hi,
I would like to know how to reset the BMW radio. I have the code but right now it just states "code - WAIT" it does not allow any numerical entries. I disconnected the power for 1 hour to see if it would reset but it didn't, then I disconnect for 24 hours and nothing happened. Is there a reset switch somewhere on the BMW radios? I appreciate any help. Thank you Last edited by Edu; 09-05-2004 at 09:57 AM.. |
Not sure about the error. Disconnect power for 1/2 hour if that makes any difference.
U have to leave the key ON for one hour-->turn on with the radio showing CODE...then after one hour enter the correct code
I will need to reset the radio code on mine. How can I find out what the code is? Will the dealership have it, or will I have to call BMW?
Thanks. |
Remove radio & there is a serial number on the back of the radio....U might be able to call a dealer but most want you to come in & show proof you own the car--->and they usually charge an hour
