Send a message via AIM to wludavid
limited slip differential lifetime
I know swapping an open diff for a used limited slip is a pretty common mod for e30 guys. Or at least it's often recommended. Anyway, since the limited slip mechanism in these diffs is a clutch-type, they must eventually wear out. What would the expected lifetime be before a used LSD turns into an open diff?
1987 325 eta
Old 09-03-2004, 08:08 PM
Simon S's Avatar
good question.
'91 318is (work in progress) / '88 Integra LSs (227K mi winter/hoop ride)
Old 09-04-2004, 05:45 AM
Simon S's Avatar
guessing from lack of response, and from research, an lsd will last a life time if properly cared for.. (fluid level maintained)
http://www.esatclear.ie/~bpurcell/318isfaults.html#differential
Old 09-06-2004, 02:20 AM
I don't think it will last forever even with proper maintainance. Clutches are based on friction, and any system based on friction will eventually wear out - pressure plates, brakes, etc.
1987 325 eta
Old 09-08-2004, 04:42 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I've heard they are good for 150K or so...
Old 09-08-2004, 07:34 AM
