cantona7's Avatar
What kind of bulbs for instrument cluster?
The left side of my cluster is not working--gas gauge and speedo. I've read the instructions for removing the cluster, but there doesn't seem to be any reference to the type and size of bulb needed to replace the originals in there. Could someone post this info? Thanks!
Old 07-07-2004, 08:56 AM
i dont know what number it is but i think its 194 or 168... not sure... go to pepbeys they have this catalogs on light bulbs for car you'll find it there...
Old 07-07-2004, 12:28 PM
7hills's Avatar
If you go thew parts store route, go ahead and replace all the bulbs in the cluster. Sometimes the new bulbs aren't exactly the same brightness as the old and your cluster still won't be lit evenly.
Old 07-10-2004, 08:29 AM
can anyone post the part#'s & quantities for a "full set" of bulbs for the instrument cluster?
trying to avoid having to take it out just to figure ou t which bulbs, then back together to drive to the store, etc, etc,.
thx!
richard
Old 08-30-2004, 09:49 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
What year and model?
Old 08-31-2004, 04:16 PM
'89 E30 325i/Sedan
Old 08-31-2004, 04:37 PM
after a bit of help from Tom in sales, I've been assured that the right assortment of bulbs for a "full set replacement" in an '89 325i instrument cluster is as follows:
> 07-11-9-978-372, 12v 3watt bulb, quantity 3. ($.70 each)
> 62-11-1-375-774, 12v 2watt bulb, quantity 2. ($1.55 each)
> 62-11-1-368-299, 12v 1.2w bulb, quantity varies per model, probably 8 would cover it. ($.75 each) (This is the small bulb that has a plastic base that 'twists' into place on the back of the instrument panel)
NOTE:
if you enter these #s into the database, tho, you get other responses/blank data ...
despite this, i'm told to ignore the database & just enter these order #s into the comment fields ...
once they arrive, i'll post a note here as to correct or not =)
richard
Old 09-07-2004, 08:27 PM
Send a message via AIM to wludavid
While we're on the topic, what type of bulb do I need to use to replace the bulbs on the 6-button clock?
1987 325 eta
Old 09-08-2004, 05:40 AM
Bijan's Avatar
Send a message via Yahoo to Bijan
On the same subject. what is the part number for the bulbs on the computer display . (to the right of the radio)
Old 09-09-2004, 11:21 AM
I'm going to put together a bulb kit for the instrument cluster.. Should help you guys out a bit...
Old 09-09-2004, 03:03 PM
