seatacus's Avatar
325e timing belt tensioner
Where on the internet can I find a tech diagram of the timing belt tensioner for a 1985 325e. Especially how relates to the water pump. My Haynes manual does not show it.
Mike
Renton,WA
1984 944 Guards Red
1985 BMW 325e
Old 09-15-2004, 06:19 PM
Send a message via AIM to wludavid
It's not on the internet, but the Bentley manual is your best bet. I know it costs ~$35, but it's well worth it. You really shouldn't try to wing this. Getting the timing belt on and tensioned correctly is somewhat finicky.
1987 325 eta
Old 09-15-2004, 08:14 PM
seatacus's Avatar
wludavid
thanks, but I am not doing the belt. I am doing the water pump and the spring and pin popped out before I could see how they go together. The belt is good.
thanks
mike
1984 944 Guards Red
1985 BMW 325e
Old 09-16-2004, 04:27 AM
Hmmm. Maybe this will help
The tensioner is part #16
1987 325 eta
Old 09-16-2004, 06:16 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
The tensioner has a bolt on one side that acts liek a pivot when the bolt is loose. The other side has a boss that a pin fits into with a spring around it. The other end of the pin fits into a slot cast into the water pump. What you do is crank the tensioner down as far as it will got and tighten the pivot bolt. Next, install the belt, then loosen the bolt and the spring will automatically tension the belt. Re-tighten the bolt.
Old 09-16-2004, 07:22 AM
I've only done one timing belt change, but I found that method did not work for me. When I loosened the bolt to "automatically" tension the belt, the pressure from the tensioner turned the camshaft gear without turning the crankshaft gear, throwing off my timing. I had to take the belt off and do it again. I wish I could remember exactly what I did...
1987 325 eta
Old 09-16-2004, 07:38 AM
seatacus's Avatar
Thanks guys, I think I've got it.
Mike
Renton,WA
1984 944 Guards Red
1985 BMW 325e
Old 09-16-2004, 03:48 PM
