can you swap out a 325e cam to an 325i cam using stock e cam gear, on a 2.7 liter block
Re: bmw e30 325 e cam swap to 325i
In the shop at Pelican
Wont work.
You'd need to modify the heads and pistons to make it work correctly, but at that point, I'd say just put a complete I motor in the car.. |
Realistically, you're not going to much out of the e motor. They were designed for torque, not horsepower.
I really wouldnt suggest putting a cam in it. You're talking about spending several hundred dollars just for the cam, and then there's the labor of having it installed, (head must be removed) It really just doesnt add up in my opinion. Better to put a i motor in. |
thanks for the reply, and you where right, way to much trouble for what its worth, even with the front of the engine apart could see that it wouldve required alot more work. anybody getting rid of an i engine and ecu?
