Pwr Steering pump leaking...rebuild or buy?
I've found that my 93 325i A?T is leaking around the seam and making a bit of a noise. Should I just replace gaskets/seals or rebuild or replace.
If replace were's a reasonable supplier??? Thanks in advance for all the replies. |
In the shop at Pelican
So the power steering pump is leaking or the transmission is leaking?
Power steering pump seam has a leak.
It's probably better to just replace it..
