gabriel_73's Avatar
turn signals
any help on this will be greatly appreciated. I own an '85 318i, and recently the right turn signal started flashing very fast (only the right the left works fine), almost 3 times faster than normal, the next day it blew the fuse, i replaced the fuse,but blew the fuse again withing a few seconds. i replaced the flasher, but the fast blinker is still there, the hazard lights bling at a normal rate. any ideas of what might cause this?
Old 10-21-2004, 04:17 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Check your bulbs. You might have one burned out, or almost ready to blow..
gabriel_73's Avatar
thank you, ill give it a try, i'll let you know if it fixes it
'85 318i
'93 318is
speed is my answer to everything!
Old 10-21-2004, 05:06 PM
yeah you probably need to replace a bulb. but on 87' 325es my left front bulb wiggles itself loose after about 5 miles or 50 miles depending on how it feels that day. errrggggghhh
Old 10-22-2004, 05:32 AM
gabriel_73's Avatar
thanks guys, that fixed it, who knew it would cost me $15 to fix a $2 problem. haha
'85 318i
'93 318is
Old 10-22-2004, 11:56 AM
Glad to hear.
Old 10-25-2004, 07:00 AM
