What brakes are these ?
I saw this while going through the brake bleeding page and was curious to what rotors these are ?
http://www.pelicanparts.com/bmw/techarticles/Mult-Bleeding_Brakes/pic6.jpg
1986 325e /// 240,000 miles 1992 318is /// 295,000 miles 1995 M3 ??? Coming Soon. Click here to see list of mods. |
Those are high proformance "cross drilled" rotors..the holes help the rotor dissapate heat in high performace driving situations..less heat =more stoping power.
1995 325i K&N air filter, clear corners and a lota fun! |
Sorry I should have been more specific. I have the cross drilled on my car I was actually referring to the color of the rotors.
oh lol sorry about that...i dont know about the color...maybe a costum job or something?
Here are the disadvantages and advantages of xdrilled rotors Advantage 1. It looks cool, yo. Disadvantage 1. most xdrilled are not cast with holes, the are drilled afterwards, decreasing the structural rigidty of the rotor. the holes often lead to cracks in the rotor, making it very unsafe (especially at the track) 2. it does not dissapate more heat. in fact, it dissapates LESS. What dissapates heat is mass. Bigger brakes, better stopping power. The holes decrease mass and thus, decrease braking power. Many people ask - if porsche and mercedes use it on their stock cars, it must have a advantageous purpose right? Yes, it does but these rotors are cast with holes which is MUCH different from the "xdrilled bling" you find online.
1997 M3 Sedan 5spd Artic Silver/Dove M3 Bumpers/Mirrors/Sideskirts S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes Oh wait...it's a stock M3 |
Ok if thats the case what ARE the advantages of "casted" cross drilled rotors?
During hard braking there is a lot of gases between rotor and pads and cross drilled rotors should help to escape this gas more quickly alowing efective braking.
so wouldent any kind of crossed drilled rotor let the gas escape?..dosent seem that the casting would effect this at all.
Drilled rotors are just known for warp problem
Even if the holes are cast during the manufacturing process, it still does not guarantee the brakes will not crack. I would assume the natural laws remain true - a solid piece is stronger than one with holes in it. Stoptech also points out how xdrilled is merely bling http://www.stoptech.com/faq/data/faq15.html Here's a pic of the xdrilled off the mercedes S class
In the shop at Pelican
I have used cross-drilled in the past. You know what I found out? You get brake fade during canyon driving, they warp and also crack. I got some good solid ventil;ated rotors, and problems went away.
I got xdrilled since they looked cool behind my BBS RK rims plus I figured it would be like sand paper the holes would dig more into the pads. I only autox and street my car have had the brakes for almost a year and no cracks or warping yet. The brand is Zimmerman.
Next is E46 330 front and e46 328 rear. I was just curious what the color of the rotors where if they had any special propertys to the metal.
