cruzinpapi's Avatar
Send a message via Yahoo to cruzinpapi
direct ignition
ignition coil # 4 not getting a signal. All injectors read 16.3 ohm. Seems like a computer fault ...any ideas. 92 325i ....
Mark
Old 11-03-2004, 04:28 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
how are you testing it? The input from the wires to the coil? Or the output from the coil to the spark plug?
Old 11-08-2004, 07:26 AM
cruzinpapi's Avatar
i pulled the coil #4 out and there is no difference. i bought a new coil no difference. i replaced all spark plugs and put a new valve gasket on. i had the injectors checked and all them read 16.3 ohm. check engine light was on changed oxygen sensor went a way for a couple weeks.
Mark
Old 11-09-2004, 12:20 PM
you didnt answer my question
Old 11-09-2004, 12:39 PM
BMW Roundel
92 wz the bad year for dme & coil problems......if ur not getting a signal then it prolly needs new dme & new coils
Old 11-10-2004, 06:04 PM
cruzinpapi's Avatar
well i guess if i tried replacing the coil that would be the output. im just wondering do i need a new monotronic control or a new computer. i already purchased all new coils. all the other coils work properly all the injectors work properly. if it is the monotronic is there a quick reset or does it need to be replaced?
Mark
Old 11-12-2004, 12:48 PM
BMW Roundel
the computer is the motronic
Old 11-12-2004, 07:01 PM
the computer->(dme) is burning up ur coils-->by just changing the coils it is only going to burn them eventually..if U dont replace ALL the coils then the old coils will burn up the new dme....U have to replace all of the above unfortunantly
Old 11-12-2004, 07:04 PM
cruzinpapi's Avatar
so i have to replace the computer aka monotronic aka dme. and also replace all coils? how much are the computers?
Mark
Old 11-13-2004, 10:07 AM
cruzinpapi's Avatar
also mine is a 92 325i is there other years dme i can use?
Mark
Old 11-13-2004, 10:08 AM
can all or some of these problems cause it to sound like it back fired?
my 325i 92 needs love.
Thanks matt
Old 02-09-2005, 09:26 AM
cruzinpapi's Avatar
matt yes
Mark
Old 02-10-2005, 12:46 PM
mark have you do all?
did one thing work that made a diff?
thanks matt
Old 02-10-2005, 03:11 PM
