93 325is door problem
I'm having problem with opening the driver side door? When I pull on the handle the door will not open unless I put a little pressure against the door with my knee,actually pushing it in slightly. Does the door need to be adjusted???
Old 02-04-2005, 09:27 AM
Send a message via AIM to Trevor
Is it possible the door panel is getting hung up? I have a similar thing happen on mine but its the passenger door so I rarely experience it.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 02-06-2005, 04:52 PM
Jeron's Avatar
Could the door be sagging? I cant remember if that is a common problem on 2 doors but you might check it out.
Could one of the door seals be out of place and preventing the door from closing all of the way?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-07-2005, 11:26 AM
jonmatar's Avatar
same thing happens to my door about every 2 months..all you have to do is get some WD-40 and open the door up and spray the lock and the striker with a good amount of lube...that should do the trick...everything just gets dried out in there and wont work properly.
1995 325i
K&N air filter, clear corners and a lota fun!
Old 02-10-2005, 08:02 PM
Jeron's Avatar
I your gonna use spray lube spend an extra buck and get a silicone based lube instead of WD-40. WD-40 can become very sticky when it dries out.
Old 02-11-2005, 07:25 AM
