E30 320iS
Hello.My name is Giorgio and i am from Greece.I find this site in google.But i know the shop.I have an e30 320is(ex 316).I have it 2 years now.I have changend all the mecanic and electric parts from the 320iS.I have a problem with the idle valve.It is not moving.I have power in the midle and mV in the two athers.In have bought also and another new idle valve and also is not working.If i put 12v in the valves both they are moving.I have also changed 2 temperature valves and the same thing.I have also change and the chip inside the ecu and the same.What you suggest?Maybe ecu problem?I want also to ask a triangle bolt in side the motronic what does?And in the thermostat i have 2 sensors.One is for the fan i thing,the ather?
Old 02-15-2005, 01:32 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
throttle switch? It controls the operation of the idle valve. It is located on the bottom of the throttle body. It may be out of adjustment.
Old 02-15-2005, 02:18 PM
No we have adjust the throtle switch.
Old 02-16-2005, 04:06 PM
Something else to check?
Old 02-16-2005, 04:07 PM
If it does the same thing with multiple idle valves, its either the switch or the wiring
Old 02-17-2005, 01:46 AM
ok i will change the trottle switch.Where i can find the electrical wiring engine and chasis?Thanks
Old 02-17-2005, 02:42 AM
um, it plugs into the the throttle switch.... what you said doesnt make sense
Old 02-17-2005, 09:47 AM
I check again the throtle valve and is ok.I have correct resistanse and when i take plug off the idle goes up.When i put the temperature sensor plug off the idle goes down.I have check the wiring from the sensors and valves and everything seens ok.
Old 02-17-2005, 12:28 PM
What do you mean by temp sensor plug?
Old 02-17-2005, 08:59 PM
When i unplug the temperature sensor the idle goes down.When i unplug the tps the idle goes up.I have check also the wiring from tps,icv,temperature sensor to the ecu plug and everything is good.Sorry for my writing is not so good and maybe i dont understant.Keep helping
Old 02-18-2005, 02:59 AM
Do you mean the sensor in the thermostat housing?
Old 02-18-2005, 08:31 PM
No the blue up from exhaust manifold.The thermostat in thermostat housing what is for?
Old 02-19-2005, 04:48 AM
Are you talking aboutt he oxygen sensor?
Old 02-19-2005, 04:25 PM
no mines and all 320is has no oxygen sensor.Up from exhaust manifold i have temperature sensor for ecu and another for indication in the instruments.This is blue for the ecu.I have also in the thermostat 2 sensors:1 is for the fun the ather i dont know.I asked you for ths sensor what is for
Old 02-19-2005, 06:49 PM
Ok, now im confused.... What year is the car?
The sensor in the thermostat should be the temp sensor, not in the exhuast manifold....
Old 02-19-2005, 07:01 PM
My car is 1990 and the mechanicals the same.Is an s14 2.0 16v known as Italian m3.It is non-catalist it has 192hp.
Old 02-20-2005, 01:00 PM
should have told me that from the start...
Old 02-22-2005, 11:38 AM
What you suppose?To wright to m3 section?You didnt know the 320iS is with s14 motor?
Old 02-24-2005, 02:48 AM
carolinus's Avatar
If your idle is changing when you unplug those things, that would mean that the ICV is working usually. What indicators do you have that it is not working?
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 02-27-2005, 02:16 PM
I have start the car cold and i have the icv plug and it is not moving.Also i have stable pressure of gasoline when it is cold and when it is hot and in all rpm.Now i have find one position whitch work good in warm position.I have also try with 12v in the valve to move it witout control from dme external and the car worked perfectly.The only problem that i have now is that when the car is cold it dont idling
Old 02-27-2005, 02:39 PM
