dsonyay's Avatar
turn signal problem
My left rear turn signal does not blink.
When I want to make a left turn, the left blinker in the car blinks very fast.
The front and side turn markers blink fast and light up, but the rear left blinker does not blink at all. I replaced the bulb but it still does not work.
The hazard lights work too- but not the left rear (same bulb).
I looked for a blown fuse, but cannot see anything blown. Is there a relay or something that may be bad??
BTW- Fuse #33 was blown which affected my interior lights and left rear running light, but that was fixed- and yes it was after changing the the A/C filter too.
All this happened after changing the microfilter. I keep thinking I did something wrong when messing with the wire harness under the glovebox. This is the 3rd time I've changed the A/C filter and never had this happen.
I'd sure appreciate some professional advice.
David S
Slidell LA- Bayou Chapter BMWCCA
Old 02-25-2005, 08:17 PM
dsonyay's Avatar
Problem fixed! I did not twist the bulb in correctly.
Old 02-27-2005, 03:05 PM
