What plugs to use...?
Hey crew- I just rolled over 61K on my '96 328i manual, and I'm trying to get some upkeep done a little at a time to control the cash flow (which is always out). Which spark plugs should I swap out with. I know Platinums are a bad idea, and I already ruled them out, but is there a specific model of Bosch plugs to look for? My friends '97 M3 plugs are $9 each for non-platinums, but the most expensive ones I've found for my car are $1.50. Thanks guys!
BMR BOY |
I believe denso and ngk both make an iridium plug for e36's. Autozone has the denso's for about 12.99. Pelican probably has it cheaper.
Platinum is not necessarily bad. I used iridium Bosch +4 $8 Autozone or Oreilly. I prefer NGK in general. I don't know plug requirements for non-M3 E36. Have you checked to see what plug you have now?
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
the bosch platinums worked ok in mine. I used the +2's for about 10000 miles. it was similar to stock.
