Send a message via Yahoo to dksix
car won't run ( jumped time ? )
I went out to start my car this mourning (1992 E36 325i ) and it would start for run for just a second and die . I kept trying to get it started and it would run longer and backfire and die . when I raised the hood I found that the idler pully on the alt. belt had came apart , The part that rides against the belt has come off and the belt was riding on the innner part of the idler . The car ran fine last night when parked and I have had no problems at all with the car ever starting . Could this be a timing issue , if so what would have caused it , Thanks for any help .
Old 05-21-2005, 09:12 AM
Jeron's Avatar
Check the belt tensioner for proper operation and replace the idler pulley. You might as well check the other tensioner, other pulley and both belts while your at it.
I wouldnt bother worrying about timing until you've fix your idle problem. You might need to charge your battery too.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-23-2005, 10:13 AM
