Air con /pollen filter
Two things.
i think my AC needs recharging...the air comes out but isnt very cold and doesnt have a huge amount or air force.
Someone has suggested that the pollen filter needs replacing to get the air to flow more freely and with more pressure.??
if so ? where is the pollen filter and how do you change it...
your help and suggestions are always appreciated
thanks
320i Convertible - Boston Green
Old 06-20-2005, 04:02 AM
Jeron's Avatar
It's in the evap coil blower box behind the center console. Just inside the firewall sitting on the tranny hump.
Remove the panel below glove box, left panel in the passenger footwell, and the glovebox. Behind the glove box unbolt the control module carrier (the big bracket with all of the wires and boxes mounted to it) and let it hang so you can get clearance to the filter.
On the side of the blower box there is a knob that twists and releases the filter. You may need to break the filter frame at 2 preassigned places to get it to fit in.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 06-20-2005, 08:11 AM
cool - will check it out later.
Old 06-21-2005, 02:07 AM
cheers dude - crystal clear instructions.
Worked a treat!
That filter was bogged up.
replaced it with a new filter...and dude it is blowing air out like mad!!!
and the ac is now working good with good pressure and very cold air.
Old 06-23-2005, 07:10 AM
