Steering Problems!
For the last couple weeks my steering has been making a whining sound when I turn. It is worse in the morning when I first start the car. I checked the power steering fluid and it is okay, could it be my power steering pump??? E36 with 93000 miles.
thanks a lot!
'87 325i
'96 328i
Old 08-17-2005, 09:37 PM
I'm not sure let me try it and I'll get back to you!
'87 325i
'96 328i
Old 08-18-2005, 08:13 AM
I discovered this morning that when i turn the wheels all the way, either direction, that the power steering makes a horrible growling noise. Bad enough that it is loud from inside the cabin of the car! What's my problem??? Please help!
'87 325i
'96 328i
Old 08-25-2005, 11:25 AM
blkongry's Avatar
Sounds like your power steering pump is going out. What it's doing is slipping past the pumping mechanism, and when you turn it all the way to the stop, then the pump gets highly loaded and starts to scream. It's time for a new power steering pump. When these go out, it's a slow and progressive process, so dont' panic... you've got a little time to shop around before it dies.
Old 08-26-2005, 08:19 AM
Jeron's Avatar
It probably is the pump but it is possible it is just the belt. If it is due for belts anyway you might give it a shot.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-29-2005, 09:42 AM
blkongry's Avatar
Yeah, if it's a squeal, then it's likely it's the belt slipping. If it's a 'whirrrrr' sound that's a little deeper, then that's the pump.
Old 08-29-2005, 11:59 AM
