94 325I vibration issue
need some help...
1994 325I drives great at crusing speeds or rpms below 5,000 and or 1/2 to 3/4 acceleration. Upon full throttle acceleration (past 5,500 rpm) it feels like the rear end is going to vibrate off. If anyone has had a torque converter fail, it feels like that-- lots of vibration. I am thinking it is the flex disc or Flex Disc Guibo, but I am not sure. Please help. |
Senior Advisor
sound s like your on target with those parts, i think thats were your problem may lie.
...96 Chevy heavily Modded such items include... lil' pine tree air freshner.... duct tape rht front arm rest (i'ts falling) zip tie holding in rear tail light.... hi concentrate windsheild washer fluid... sticker of Speedy Gonzales..rear bumper... |
You should try givin lonely house wife’s rides in your trunk. That'd really make em happy.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
I have the same exact problem! Mine has gotten worse over the months, anytime I try to floor the car in 2nd gear, no matter what rpms, it'll shake and thud and rattle and feel like the whole car is gonna break.
I thought maybe it was due to bad exhaust hangers, I have yet to check. Can anyone pinpoint what this problem is? I'm going to have to take it into the shop to try and figure it out! |
In the shop at Pelican
I concour with above, it sounds like it is either the torque converter or the Guibo Coupling. Have you checked your ATF level lately?
had it checked in july. the car mostly sits. i've been trying to sell it lately, and the last to test drive it thought he was michael andretti. He wanted to make sure the rpm limit was really bumped up due to the chip i guess. Almost knocked him out after that one. ATF Should be ok.
1994 325I OEM M3 Front Bumper, Trim, Fog Lamps OEM M3 M-Kontur 17" wheels Brand New Tires OEM M3 Cat Back Exhaust Bilstein Sport Suspension w/ Racing Dynamic Springs Racing Dynamic Sway bars BMP Strut Tower Braces All New Brakes & Rotors White & Clear Rear Lamps, Clear Turn Signals Custom All Black Interrior - like 97 M3 Sedan 124,000 Miles $9,500 Or Best Offer njrealtor55@yahoo.com |
ALSO CHECK YOU SUB FRAME BUSHINGS, IF THEY ARE BAD THEY CAN MAKE SOME FUNNY NOISES IN THE REAR END UPON ACCELERATION.
Did anyone ever figure out exactly what this problem was? I'm dealing with the same thing now.
'93 325is |
