Send a message via AIM to njrealtor55
94 325I vibration issue
need some help...
1994 325I drives great at crusing speeds or rpms below 5,000 and or 1/2 to 3/4 acceleration.
Upon full throttle acceleration (past 5,500 rpm) it feels like the rear end is going to vibrate off. If anyone has had a torque converter fail, it feels like that-- lots of vibration.
I am thinking it is the flex disc or Flex Disc Guibo, but I am not sure.
Please help.
Old 05-06-2003, 08:21 AM
Senior Advisor
Javier at Pelican Parts's Avatar
sound s like your on target with those parts, i think thats were your problem may lie.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 05-06-2003, 11:28 AM
supertack's Avatar
You should try givin lonely house wife’s rides in your trunk. That'd really make em happy.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 05-06-2003, 12:03 PM
stupenal's Avatar
I have the same exact problem! Mine has gotten worse over the months, anytime I try to floor the car in 2nd gear, no matter what rpms, it'll shake and thud and rattle and feel like the whole car is gonna break.
I thought maybe it was due to bad exhaust hangers, I have yet to check.
Can anyone pinpoint what this problem is? I'm going to have to take it into the shop to try and figure it out!
Old 05-06-2003, 02:55 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I concour with above, it sounds like it is either the torque converter or the Guibo Coupling. Have you checked your ATF level lately?
Old 05-06-2003, 02:57 PM
had it checked in july. the car mostly sits. i've been trying to sell it lately, and the last to test drive it thought he was michael andretti. He wanted to make sure the rpm limit was really bumped up due to the chip i guess. Almost knocked him out after that one. ATF Should be ok.
1994 325I
OEM M3 Front Bumper, Trim, Fog Lamps
OEM M3 M-Kontur 17" wheels Brand New Tires
OEM M3 Cat Back Exhaust
Bilstein Sport Suspension w/ Racing Dynamic Springs
Racing Dynamic Sway bars
BMP Strut Tower Braces
All New Brakes & Rotors
White & Clear Rear Lamps, Clear Turn Signals
Custom All Black Interrior - like 97 M3 Sedan
124,000 Miles
$9,500 Or Best Offer
njrealtor55@yahoo.com
Old 05-07-2003, 04:40 AM
BIG SHATTUCK's Avatar
ALSO CHECK YOU SUB FRAME BUSHINGS, IF THEY ARE BAD THEY CAN MAKE SOME FUNNY NOISES IN THE REAR END UPON ACCELERATION.
Old 05-10-2003, 09:40 AM
n.10.z's Avatar
Did anyone ever figure out exactly what this problem was? I'm dealing with the same thing now.
'93 325is
Old 09-17-2005, 11:56 AM
