Odometer light out. Help!!
1996 328 i , my wife's car .
My odometer light has gone out and I can't read the mileage at night . How do you change the bulb ?? Can anyone help how to repair ? Thanks Last edited by vincenza; 09-19-2005 at 10:40 AM.. |
I'm with Bill
Remove the instrument cluster and replace the bulb.It's got a small black plastic base on it and requires a quater turn to remove. You may as well replace all the little indicator bulbs while you are there save yourself some agg. down the road.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Does your odometer have a digital display? If it does you will need to replace the cluster. Mine is intermittently illegible, & I was told that internal parts are not available for those digital clusters.
They typically go for around $100 on EBay, then you'd need to have someone program the correct mileage, & get rid of the red replacement cluster indicator light. I'm in the process of doing mine, total cost is gonna be around $250. Kinda a drag for such a minor thing.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
Rick how do you replace the bulb only ?
Do I need to remove the whole dash ? Thanks , VS Last edited by vincenza; 09-19-2005 at 10:41 AM.. |
I'm with Bill
You only need to replace the bulb if the numbers are visable just not light up. Start the car in the sunlight or bright area and see if the numbers are there. If they are a bulb will do it. If they are not there than follow supertracks post.
To remove the cluster just remove the 2 screws that hold the IC in place they are located in front of the lense on the top fo the cluster. juntly pull out on the top and roll it towards the steering wheel. If you have a tilt wheel pull it all the way down. Un hook the wire conectors and pull the IC into the top of the wheel(in the straight position) Jently turn the steering wheel to the left with the IC in it. The IC will roll out but be very carefull with the turnsignal switch it may scratch the lense of the IC. Replace the bulbs and reverse the procedure. It sounds much harder than it is. You can remove the wheel and it is much easier but you will end up with a hard code for the airbag and it will have to be reset, It won't clear itself and the light will be on.
Rick thanks so much .
I can see the numbers so it's only the bulb. Thanks again for all your help Vince Spagnuolo |
