how do I get the "change oil"lights out
What's the secret to getting the lights out in the center of my dash? the manual does not give a procedure for those of us who change our own oil. thanks, hushpuppy
Old 01-05-2007, 05:57 AM
Jeron's Avatar
For the E36 you need a Peake tool or there is a procedure to short two of the pins in the diagnostic post. Try a couple of searches on this forum, I"m sure its been discussed here a few times.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-05-2007, 06:24 AM
Re: how do I get the "change oil"lights out
This should help you, this is what I made up for a few pence.
Here is the link .
http://www.unofficialbmw.com/e36/electrical/e36_reset_service_lights.html
Old 01-07-2007, 05:20 AM
thank you! just as you said, grounding pin 7 turned out the light. Just one difference on my E 30 325 ix was the location of the toward the front left side of the intake plenum. thanks again.
hushpuppy
Old 01-12-2007, 09:31 AM
Send a message via AIM to obs0lete
Just did the same procedure to my 1995 325is and worked out Great.
Grounded Pin 7 on the DLC for roughly 3.25 seconds and then again for 11 seconds for the other service light, now both of my service lights are cleared.
I just used wire with alligator clips from ground to Pin 7 rather than using resistors as he did on the write-up on the site (although that would be safer if you accidently grounded the wrong pin or something.)
Good luck to others who try this out.
Old 01-21-2007, 05:27 PM
