hello there,
why do the revs drop when the drivers door is shut on a 95'bmw 318is??? |
Does it drop just for a moment or does it drop and stay low?
My guess is it is a voltage drain or short. If it is, then it is the alternator sucking power from the engine causing the rpm drop.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Thank you for your replay..
The revs drop only for a moment and then go back up. this also happens when the headlights are turned on and when i wind the windows all the way up. So you think that i should change the alternator? |
Does your car have frameless windows that drop and raise when the doors are opened and shut?
The RPMs drop on my M3 due to headlights and windows. I wouldnt change anything unless the RPM drop is a problem. You might check and clean the connections at the battery and the alternator.
Thanks alot for your help.
yes i do have frameless windows. ok ill give the connections a clean. Once again thank you very much. |
Sounds like the revs drop due to the window roll up when the door is shut. If it is too extreme then the window travel may need to be adjusted. I think the procedure is to hold the button UP for 10 seconds but you should check to be sure. We have discussed it in the E36 forum, I think blkongry had the answer.
I think there is nothing wrong and the small RPM drop is normal.
Sorry if I'm pointing out the obvious, but I'd try lowering the windows (so they won't go up/down when the door is opened/closed) and then closing the door to see if the RPMs drop. I think Jeron has properly diagnosed the problem, but I'd do this just to confirm.
