Angry E36 318i Sway Bar Drop Link Replacement
The right rear drop link that connects the sway bar to the suspension on my 1997 318i is broken, literally snapped in half. I will get a new one but I absolutely can not fugure out how to get the broken one of the sway bar.
I've taken the whole sway bar off the car and all I need to do is take off this drop link off of the end of the sway bar.
SOMEONE PLEASE HELP
Old 12-20-2005, 12:26 PM
Do you mean part 7 here http://www.realoem.com/bmw/showparts.do?model=CC93&mospid=47493&btnr=31_0267&hg=31&fg=10 can't see the problem, just undo the nut.
http://www.parengstrom.com/bmw.htm
Old 12-21-2005, 01:36 PM
Jeron's Avatar
I've never removed a rear link, I run aftermarket bars now, but I'm pretty sure rear link slips on. You might need a puller.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-21-2005, 02:00 PM
This is the exact part right here and it's number 5, there's nothing really holding it on it's just a rubber bushing on the bar and I've pulled it hard enough to break but it doesn't budge, do I need to get another sway bar or what?
http://www.realoem.com/bmw/showparts.do?model=CC93&mospid=47493&btnr=33_0364&hg=33&fg=45
Old 12-21-2005, 09:15 PM
ok, sorry, I thought it was the front one....so it's just the metal sleeve and some rubber left then. Try use a puller to remove it, You might try and heat it aswell
Old 12-22-2005, 12:47 AM
Jeron's Avatar
If you dont have a puller, how about some silicone spray, a hammer and a chisel (craftsman screwdriver). Stand it on end and hit downward. A partner might help.
Old 12-22-2005, 07:45 AM
