Suspected radiator leak
I have a 92 325i that is leaking coolant...somewhere. I have checked all the hoses and cannot find where the leak is. I suspect it might be the radiator itself. There are times when I can smell the sweet odour when the heater fan is on.
My question is, should I use a radiator sealant and if so, where do I pour it? Thanks Shirley J |
I would not use radiator sealant. I would try to find the leak first. Obviously checking near the heater core should be your first stop.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
I do not like the radiator sealant either. Any spots on the floor? I was thinking the 6cly had radiator problems. 92 model, how many miles on your cooling system?
318i Convertible, 5speed, 125k |
Hi Shirley,
I would not use any sealers. I have a '89 535 and just got a '99 m3. Both cars Loose coolant and I can not find where it goes. I just add it to both cars each month. On the 535 I was hell bend on finding where the coolant was going, I changed the heater core because their was not a sign of coolant any were, after changing the core I was still adding coolant. I have been working on cars for 30 years and I can not figure where the coolent is going. The 535 has a extra 35k miles since I got it and the lost coolant does not seem to bother the car. Good luck and just keep adding coolant. |
If you loose coolant you might consider putting in some new BMW coolant. BMW coolant has a chemical in it that leaves a white powdery residue when it evaporates. This makes it fairly easy to find leaks.
Other than that one benefit I can't bring myself to pay $20 a gallon for coolant. Oh, and yes BMW's do have radiator problems due to the plastic components but the common problems are usually catastrophic.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 Last edited by Jeron; 01-21-2006 at 10:29 AM.. |
Hi shirleyj,
I had a similiar problem with my car during the summer. If you suspect that you have a coolant leak, then I would bring it to a reliable mechanic and have a pressure test done to check for the leak. |
