94 325i tach issue
I have a 1994 325i convert. My tach and mpg meter have stopped working. I recently changed the spark plugs, started up the car, and the revved the engine. The tach was working fine. Next I disconnected my battery to clear a check engine code in my ECU. I have disconnected and reconnected the battery before, and never had a tach problem. However this time when I reconnected the battery, the tach stopped functioning. Did I do something wrong and what can be done to regain my tach functionality?? Thanks for the help
Old 12-31-2005, 02:31 PM
Jeron's Avatar
Make sure you reattached all of the ground wires when you changed the plugs. Check for water in the ECU compartment.
I think you can disconnect the battery cables and hold them together for a few seconds to reset the ECU, but you should get a second opinion before trying it.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-03-2006, 08:03 AM
Update: I rechecked the ground wires and all were reconnected. Now the temp gauge does not work at all either, which is a serious problem. I have not checked for water in the dme, but what I don't understand is how disconnecting or reconnecting the battery could have cause this problem...unless it was one serious coincidence..
Old 01-09-2006, 08:26 PM
