Send a message via AIM to Bear
Instrument Cluster Troubleshooting
1990 325ic and the left turn signal indicator n the instrument cluster does not illuminate. The turn signal works, the flasher clicks, and I have changed the bulb, even swapped out the bulb from the right side indicator that does work and still she is blank. Do I need to pull the back off of the cluster and re-flow the solder to the bulb socket?
Old 01-25-2006, 04:18 PM
m78 m78 is offline
Yes. Take the cluster out. it's not too difficult. I advise taking the steering wheel off first. And take the cluster out. It will either need new solder or a new motherboard.
Mine did the exact same thing. I just replaced with an ebay motherboard. And it works perfect.
Old 02-09-2006, 12:30 PM
