-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Fault codes (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/265583-fault-codes.html)
LiquidBMW76 02-09-2006 02:17 PM
Fault codes
I did the fault code check for my car and the same code kept cycling through. I never got the short 1000 code. Anyone have this problem or know how to reset it. It drives me nuts I sat there for at least 30 minutes at one point.
Jeron 02-10-2006 07:45 AM
I remember hearing that in this forum.
yob 02-10-2006 12:57 PM
same thing happens to me if you figure it out let me know
Jeron 02-10-2006 01:08 PM
I thought when this happened it was showing a legitimate error code but it just kept showing it over again and never showed the finished code.
If you think the error code it shows is not valid then clear the codes and see if any new codes come up.
LiquidBMW76 02-10-2006 01:11 PM
That is just it I can't figure out how to clear the codes. Any help would be greatly appreciated.
Jeron 02-10-2006 01:26 PM
I almost volunteered that info in my last post. Guess I should have.
The answer is in the other thread active thread of today:
http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/265671-display-any-idea.html
You need a code reader which will reset the CEL. You can buy it from Pelican.
