Fault codes
I did the fault code check for my car and the same code kept cycling through. I never got the short 1000 code. Anyone have this problem or know how to reset it. It drives me nuts I sat there for at least 30 minutes at one point.
Old 02-09-2006, 02:17 PM
Jeron's Avatar
I remember hearing that in this forum.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-10-2006, 07:45 AM
yob yob is offline
same thing happens to me if you figure it out let me know
Old 02-10-2006, 12:57 PM
Jeron's Avatar
I thought when this happened it was showing a legitimate error code but it just kept showing it over again and never showed the finished code.
If you think the error code it shows is not valid then clear the codes and see if any new codes come up.
Old 02-10-2006, 01:08 PM
That is just it I can't figure out how to clear the codes. Any help would be greatly appreciated.
Old 02-10-2006, 01:11 PM
Jeron's Avatar
I almost volunteered that info in my last post. Guess I should have.
The answer is in the other thread active thread of today:
Display..Any Idea
You need a code reader which will reset the CEL. You can buy it from Pelican.
Old 02-10-2006, 01:26 PM
