DFL DFL is offline
brake light failure
1995 325i
I just got an error "1 brake light failure". Checked and the right one is definitely out. Swapped out the left one that works, and it does not light up. What else is there?
Old 03-22-2006, 11:45 AM
It might not work because when you took the left one out you may have created an open circut. Try putting the light bulb back in the left and replacing the bad right bulb it should fix it.
1993 318i manual
Old 03-22-2006, 03:31 PM
Jeron's Avatar
Also check the contacts in the socket and bend them to touch the bulb more securely. Get some dielectric compound to make a better connection. Use a circuit tester to make sure there is power to the socket mount.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-22-2006, 04:14 PM
DFL DFL is offline
I did leave the other bulb out when I checked it; I will try again when I get home from work. I will also try using a circuit tester. Thanks for the input. I will let you know what happens.
Old 03-23-2006, 06:30 AM
DFL DFL is offline
Swapped out left to right, no change. I turned on the lights and that bulb is working. Is there a switch under the brake pedal that activates that side? As soon as you step on the brake the error message comes on and that side does not work.
Old 03-23-2006, 12:47 PM
If I'm correct there is only one switch and it operates all of the brake lights. Is the dead side getting any power to the socket if not you have a wire grounded somewhere.
1993 318i manual
Old 03-23-2006, 12:56 PM
Jeron's Avatar
Some early E36's (Pre 96?) had a problem with the wires wearing though the insulation where the wire loom enters the trunk lid.
Did you check the socket too? Or try swapping the socket AND bulb side to side?
Old 03-23-2006, 01:01 PM
DFL DFL is offline
If the tail light is working on that side, then I assume that the socket is getting power. Just the brake light is not working? Any chance the housing itself has gone bad somehow?
Old 03-24-2006, 06:29 AM
DFL DFL is offline
I'll check the wiring loom tonight. I hope I find the problem before we all run out of ideas!
Old 03-24-2006, 06:33 AM
jtmc325's Avatar
I have a 95 325I and had the same problem. Replaced the brake light switch behind the brake pedal, will have to remove the drivers lower dash panel. Its not very hard, just hard to get to. The switch goes in a metal bracket and is hard to get out, just brake the old one off and snap the new one in place. I have not had that problem since changing the switch, should be less than $20.
Old 03-24-2006, 01:17 PM
Ad Hoc's Avatar
The brake light switches are notorius culprits.
Also, a related issue although not necessarily on point for your specific problem is that in my 93 325i if I don't use identical bulbs in each side for any bulb replacement (i.e., purchasing and installing a pair of Sylvania bulbs), my computer will display error messages - very persnickity.
Old 04-08-2006, 02:39 PM
Jeron's Avatar
I thought brake light switches threw a "brake circuit failure" on the computer.
Old 04-11-2006, 06:19 AM
