-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   What is this part called? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/279655-what-part-called.html)
ceaz 04-27-2006 02:55 PM
Hi all, my 1994 325is recently overheated and it was because this part had broken off. I'm not a mechanic so I don't know what it is called but I will try to describe it as best I can.
When I open the hood, it is on the driver's side, almost underneath where the bolt of the middle windshield wiper is located. I had to unscrew the cover just underneath the windshield wiper, about a foot and a half long, to get to this part that needs replacing.
It is a black 3 prong, threaded plastic piece about 2-3 inches long that 3 hoses connect to. I'm assuming that one of them is somehow connected to the coolant, because lime green fluid was leaking from the prong that broke.
I can install the part, but have had no luck trying to locate the part , since there are to many parts to go through in the catalog. Any help from anyone would be much appreciated.
LiquidBMW76 04-27-2006 09:34 PM
Try using this to figure it out. http://www.realoem.com/bmw/
Jeron 04-28-2006 07:28 AM
Sounds like the heater valve assembly.
HEATER AND AIR CONDITIONING => WATER PUMP, VALVE, HOSES
http://www.realoem.com/bmw/showparts.do?model=BF33&mospid=47484&btnr=64_0126& hg=64&fg=18
