ceaz's Avatar
Question What is this part called?
Hi all, my 1994 325is recently overheated and it was because this part had broken off. I'm not a mechanic so I don't know what it is called but I will try to describe it as best I can.
When I open the hood, it is on the driver's side, almost underneath where the bolt of the middle windshield wiper is located. I had to unscrew the cover just underneath the windshield wiper, about a foot and a half long, to get to this part that needs replacing.
It is a black 3 prong, threaded plastic piece about 2-3 inches long that 3 hoses connect to. I'm assuming that one of them is somehow connected to the coolant, because lime green fluid was leaking from the prong that broke.
I can install the part, but have had no luck trying to locate the part , since there are to many parts to go through in the catalog. Any help from anyone would be much appreciated.
Old 04-27-2006, 02:55 PM
Try using this to figure it out. http://www.realoem.com/bmw/
1993 318i manual
Old 04-27-2006, 09:34 PM
Jeron's Avatar
Sounds like the heater valve assembly.
HEATER AND AIR CONDITIONING => WATER PUMP, VALVE, HOSES
http://www.realoem.com/bmw/showparts.do?model=BF33&mospid=47484&btnr=64_0126&hg=64&fg=18
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 04-28-2006, 07:28 AM
