Replacing an analogue clock with an OBC?
Hi
I've got a 1999 318is Coupe that currently has an analogue clock installed. How easy would it be to install an 18 button OBC and what would be involved? Any pointers appreciated.
Cheers
Andy
Old 05-05-2006, 12:50 AM
supertack's Avatar
I've contemplated replacing my 11 button OBC with the 18 button unit. Of what I've read up on the mod, it's pretty in depth with a lot of frickin wires to run.
Mind you, this is already with an OBC in place. If your trying to start from scratch, ...................um, I hope you really, really, really want that OBC.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 05-06-2006, 08:16 AM
