Steeve's Avatar
Coolant Expansion Tank
Ok, I found a huge crack in my coolant expansion tank this afternoon. I ordered one from Pelican (of course). How tricky is it to replace? I am not overly handy, so I was wondering if this is a relatively simple replacement, or if I should just give it to my mechanic?
OOPS: yes this is for my '98 323 iC
'86 911 targa
'04 MB 230K Sport (daily)
Old 05-06-2007, 05:33 PM
Jeron's Avatar
Its easy but I'm pretty handy. Make sure you properly bleed the system afterwords. Directions are in Tech Info.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-06-2007, 07:44 PM
supertack's Avatar
Here's a couple helpful links.
http://www.bimmerboard.com/forums/posts/46816
http://www.bimmerboard.com/forums/posts/186156
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 05-07-2007, 10:48 AM
