Suthrnr's Avatar
Turn signals
I have a 95 325 is. A problem just surfaced. When I make a right handed turn and put on the turn signal all turn signal lights come on (like a hazard light) but when I turn left the turn signal works normal. I am at a loss as to what causes this, and or what to replace. Also on occasion the “brake light circuit” will show on the display screen. Often I can turn the car off and then on a again and it goes away. Happens about once a week?
Old 12-18-2006, 06:29 AM
Jeron's Avatar
If its an E36, I would start with the damaged wires in picture/figure two here:
http://www.pelicanparts.com/bmw/techarticles/101-Projects-82-Electrical-Problems/101-Projects-82-Electrical-Problems.htm
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-18-2006, 07:37 AM
Suthrnr's Avatar
Any idea where you think I should begin?
Old 12-18-2006, 08:01 AM
Jeron's Avatar
At the bottom of that article there are two pics. The second one is of damaged wires in the loom where it enters the trunk. I would check there first.
Old 12-18-2006, 08:20 AM
Suthrnr's Avatar
got it. Thanks
Old 12-18-2006, 08:31 AM
