unknown scan ņodes P1268
Hi
I have 318iS Coupe, m42 engine, e36. I keep getting the following code when my check engine light comes on: P1268. I cannot find that it for a code. I cannot reset this code. I do not see last code 1000. ----- Danik |
Are you sure that is the correct code? I can not find that code anywhere except as an 8th cylinder fault in Dodge trucks.
http://www.pelicanparts.com/BMW/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm |
Yes. Code correct.
I found this code in Autodata 2005. MAF sensor error. How clear this code from DME?
You can clear it with a Peake tool or other code reader. The local autoparts store might be able to clear it for you.
| All times are GMT -8. The time now is 08:28 PM. |
