unknown scan ņodes P1268
Hi
I have 318iS Coupe, m42 engine, e36.
I keep getting the following code when my check engine light comes on: P1268. I cannot find that it for a code.
I cannot reset this code. I do not see last code 1000.
Danik
Old 05-14-2006, 10:08 PM
Jeron's Avatar
Are you sure that is the correct code? I can not find that code anywhere except as an 8th cylinder fault in Dodge trucks.
http://www.pelicanparts.com/BMW/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-15-2006, 11:23 AM
Yes. Code correct.
I found this code in Autodata 2005. MAF sensor error. How clear this code from DME?
Old 05-17-2006, 10:29 PM
Jeron's Avatar
You can clear it with a Peake tool or other code reader. The local autoparts store might be able to clear it for you.
Old 05-18-2006, 07:04 AM
