Oxygen sensor
I have a 325i pre cat e30 I Have replaced the blue injectors with units from a 535 the engine now runs very rich. Could I fit an oxygen sensor, if I do which pin of the ECU to I send the control voltage or could I just feed a voltage to the ECU and set the mixture manually?
I am in the UK Regards John |
Yikes, I think that you are asking for trouble on this one. Why did you replace the injectors with ones from a larger engine? The only way to really solve this problem, may be to put a pressure regulator on the line to reduce the flow from the injectors...
-Wayne |
| All times are GMT -8. The time now is 04:05 AM. |
