Oxygen sensor
I have a 325i pre cat e30 I Have replaced the blue injectors with units from a 535 the engine now runs very rich. Could I fit an oxygen sensor, if I do which pin of the ECU to I send the control voltage or could I just feed a voltage to the ECU and set the mixture manually?
I am in the UK
Regards
John
John
Old 07-01-2006, 09:03 AM
Author of "101 Projects"
Wayne 962's Avatar
Yikes, I think that you are asking for trouble on this one. Why did you replace the injectors with ones from a larger engine? The only way to really solve this problem, may be to put a pressure regulator on the line to reduce the flow from the injectors...
-Wayne
Old 10-09-2006, 01:11 AM
