Ticking sound in drive shaft
I have a 1993 325is with an automatic transmission it has 90,000 K. When the weather got cold I noticed that when the car started moving I could hear and feel a ticking or clicking sound from the drive shaft area under the shifter. When I go faster the noise would tick faster. Engine speed and gear selection don’t change the sound frequency. When the car warms up the ticking goes away. Any thoughts would be appreciated.
Old 02-19-2007, 07:02 AM
Could be your guibo.
Old 02-19-2007, 10:29 AM
So the guibo is used rather than a u-joint? I have only had a BMW 9 months.
Old 02-19-2007, 11:19 AM
Guibo is used in addition to the u-joint.
Old 02-19-2007, 11:46 AM
So if I have to drop the exaust pipes to get to the guibo would it be wise to replace the u-joints and the center hanger bearing? Also, when you drop the exaust pipes to you need any new gaskets when puting back together?
Old 02-19-2007, 12:06 PM
Unfortunately, it is hard to draw the line (it's only money), but I would replace the u-joints. If you cal just lower the exhaust system to gain access without taking it apart, then it should be safe to stick with the same gaskets, otherwise, you never want to reuse old gaskets.
Old 02-19-2007, 02:16 PM
Jeron's Avatar
You should be able to see and touch the guibo at the back of the tranny without removing any parts. You are looking for frayed rubber that is slapping the tunnel.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-19-2007, 06:03 PM
