Rubatoguy's Avatar
Send a message via AIM to Rubatoguy Send a message via Yahoo to Rubatoguy
pinging
My '93 325i automatic has a problem with pinging under a light load. For example, going up a slight grade at about 30-40 mph.
The car has had a tune up, the fuel injectors cleaned, and the fuel pump replaced (which improved the problem but did not eliminate it.)
Is there anything else to check which might cause this? I thought these cars had detonation sensors which prevented this problem.
The only other thing I can think of would be that the car has a vacuum leak somwhere - but it does not look obvious by looking at the vacuum gauge aka MPG gauge.)
Any tips on what else to look for?
Todd
'93 325i
Old 02-19-2007, 12:47 AM
Rubato,
Are you using 93 octane gasoline? If not, then try a tank-full.
Old 02-19-2007, 06:29 AM
Rubatoguy's Avatar
pinging
I've been using 89 Octane Shell Plus grade.
I thought that was within the octane requirement sticker on the car. Is that not correct?
Old 02-19-2007, 09:27 AM
I thought that it required at least a 91 octane rated gas. I would just try a tank-full, what can it hurt?
Old 02-19-2007, 10:27 AM
