Rubatoguy's Avatar
Send a message via AIM to Rubatoguy Send a message via Yahoo to Rubatoguy
Oil Leak '93 325i
I have an oil leak that I am told is the oil pan - The mechanic says that replacing the oil pan gasket is a 5 hour job because you have to lift the engine up in order to replace the gasket.
Are there any tricky ways to do this without having to raise the motor?
Old 08-09-2006, 10:32 PM
Author of "101 Projects"
Wayne 962's Avatar
You do not have to raise the engine in order to replace the oil pan. You can "simply" drop the front suspension to achieve the same thing. In my opinion, dropping the suspension is far easier than lifting the entire engine. Actually, you only need to drop the front support bar underneath the engine - not any of the struts, etc. It's a complicated job, but pretty straighforward. This is all documented in my new 101 Projects book...
-Wayne
Old 08-10-2006, 02:24 AM
Rubatoguy's Avatar
Well, that is definately worth the cost of a book!
I already have the 101 projects for the Porsche 911 and it was a worthwhile purchase
Todd
Old 08-10-2006, 08:10 AM
Wayne 962's Avatar
If you are only replacing the oil pan seal, you may even be able to get away without dropping anything. Here's a trick, I've been meaning to try:
Remove the lower oil pan cover, and let it drop against the suspension - you should have about a half inch or so clearance now to remove the old seal. Work carefully and remove all the old bits of seal. Now, take the new seal and cut it, so that you can place it around the pan without having to go underneath the oil pump. Apply some gasket sealer at the slit, and then rebolt the pan.
On some cars, there are two pans, this might not work with both of them, but I suppose it's worth a try. On my E30 that I performed this on, I distinctly remember thinking that I didn't really have to drop the suspension if I wanted to try this...
-Wayne
Old 08-10-2006, 01:17 PM
Jeron's Avatar
It seems you might be able to work the gasket onto the pan from below without cutting the gasket. It's worth trying at least.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-10-2006, 01:22 PM
Wayne 962's Avatar
Yes, on different cars, you might have some room down there. However, on some, I will tell you that it will be a lesson in frustration.
-Wayne
Old 08-10-2006, 02:08 PM
I don't think it could be done without cutting the gasket. The oil pick up sits quite low in a baffle. Here is a shot of the oil pan. The factory baffle is sitting on top (I took this shot to show the Turner baffle kit I welded in). The oil pick up sits inside the large hole in the baffle which is mounted to the bottom of the pan.
I did this job over the winter while replacing the entire suspension. I'll do a write up on it this weekend.
Keith
87 325i
96 328is
85 318
Old 08-11-2006, 08:10 AM
