stuck fuel pump
1987 325i conv. manufactured in nov.
can't get fuel pump out of gas tank.
elect, and fuel disconnected.
hanger/pump assembly is disconnected from tank, but unable to maneuver it out.
Old 06-01-2012, 02:37 PM
undo thoses 4 8mm nuts and remove the fuel level sending unit, then you can rotate the main housiing and remove the pump, there is a flat section on the base, so angle it over when almost removed.
Old 06-03-2012, 12:44 PM
