james39's Avatar
Question Brake Light Circuit Warning
What causes the computer display to intermittently flash "Brake Light Circuit Warning Check Owner's Manual"
Bently manual doesn't address this. Any help?
James39
Old 09-13-2006, 07:50 AM
Author of "101 Projects"
Wayne 962's Avatar
What year is your car? This can be caused by a number of things, but most common is a failure of the brake pedal switch. The early cars did not give this message when the switch failed, but the later ones did. Here's the article on the switch replacement:
http://www.pelicanparts.com/bmw/techarticles/E36-Brake_Switch/E36-Brake_Switch.htm
-Wayne
Old 09-13-2006, 10:44 AM
Wayne 962's Avatar
Here's the link to the part in our catalog:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=BE36&section=Ppedal&page=1&bookmark=1&part_number=61-31-8-360-417-M64
-Wayne
Old 09-13-2006, 10:45 AM
Jeron's Avatar
Almost always the brake pedal switch, assuming it's an E36.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-13-2006, 11:06 AM
supertack's Avatar
Most definitely the switch if all your rear lamps light. I had to change mine out last week. Pretty simple, & not very costly.
A Couple points on the change. First, to get the old one out you basically have to destroy it by prying it out with a pliers. I had to break mine into a thousand pieces. Second & most importantly, make sure you slide the red collar of the switch forward, & hold down the brake pedal (with your hand) before trying to snap the new one in. The switch is engineered in such a way that it's self locking with the red collar in place. If you don't depress the break pedal, the collar will slide back, & you won't be able to snap the switch into place no matter how much force you use.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 09-14-2006, 05:43 AM
james39's Avatar
Question Brake Light Warning
My car is a 95 325iC. Checked brake lights last evening. Brake lights work. Still think the switch is causing the "Brake Light Circuit Warning"?
Old 09-14-2006, 06:22 AM
Wayne 962's Avatar
Re: Brake Light Warning
Yes, I think (not sure) that there are two circuits inside this switch - a primary and a secondary. When one fails, it gives this message. I would bet lunch that this is the problem...
-Wayne
Old 09-15-2006, 12:52 AM
Re: Brake Light Circuit Warning
James39
Hi james well this has happened to me a few times last week
all the light were OK, so I took all the bulb holders out to check for corrosion and they looked fine, when I put them all back the problem was fixed. Have done a couple of hundread miles since then on country roads.
Old 09-18-2006, 12:23 PM
